Originally Posted by MkVer
I'd do the same but first if you have any to spare cut out a bit and stick it to the underside of the hood to see how it handles the heat. It'd probably be better to find out a 1sq inch tab melts or catches fire than have the whole hood burst into flames.
Good point, fiberglass insulation is generally fire retardant but foam not so much.
