Old 10-26-2015, 01:37 AM   #4 (permalink)
Andyman
amateur mech. engineer
Sporty Accord - '88 Honda Accord LX-i
90 day: 23.25 mpg (US)
Dad's Camry - '01 Toyota Camry CE
90 day: 22.81 mpg (US)
Artie's Camry - '98 Toyota Camry
90 day: 37.3 mpg (US)
I just wrote some paragraphs in a Quick Reply box but it all got deleted when it said that I was not logged in. Apparently that is what happens if someone takes too long to write a reply. It would be a good idea to use a copy command to save the text before using the "Post Quick Reply" button.
Briefly, what I said is that I fixed a check engine light problem by tightening the coolant temperature sensor connector and retarded the ignition timing a bit to stop the knocking. I still need to fix the starter motor and sometimes the engine stalls.
I want to modify the automatic transmission so it will engage the torque converter clutch at 25 mph (in third gear) instead of 48 mph in fourth gear only. I need to find a hydraulic diagram to understand how it works.
