Main problem I see with that hydraulic motor is its only going to make like 80 foot pounds of torque.
Huh???
You can get a hydraulic motor in almost any RPM and torque rating you could ever want. If you find a good deal on a motor that isn't perfect, gear ratios, or pulley ratios, are extremely easy to change. Hydraulic motors are available in high speed, low speed, high torque, and low torque. Just like a gas motor. Your post doesn't make any sense.
But for that matter I am not talking about a complete engine replacement, 80 ft lbs of torque is a LOT if it's just a booster.
