Old 10-27-2015, 09:27 PM   #105 (permalink)
Vman455
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
The air dam experiment has begun! I bolted some L-brackets onto the bumper cover:
Uh oh--OSHA inspectors.
Lawn edging bolted to the brackets, all stainless hardware. I took the opportunity with the bumper off to get rid of the pipe foam grill block; instead, I used one of the hatch panels I had taken off and cut it up to be a permanent grill block zip-tied behind the slats, with a center opening in the lower grill under the license plate and the inward side of both upper grills still open.
Back on the car:
Still a little more than 4" clearance, about the same as the 1st gen Volt with original air dam.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following 7 Users Say Thank You to Vman455 For This Useful Post:
aerohead (10-28-2015), bikeprof (07-07-2016), mcrews (08-12-2016), MetroMPG (10-29-2015), ME_Andy (10-27-2015), UFO (10-29-2015), whatmaycome14 (11-16-2015)
