Old 10-27-2015, 10:21 PM   #5 (permalink)
user removed
Bad:
Thermostat.
Oxygen sensor.
Timing-distributor.
Compression.
Fuel pressure regulator.
Timing belt installed incorrectly.
Brakes dragging.
Plugged converter-exhaust.
Low air pressure in tires.
Dragging brake calipers.
Very short driving distances.
Alignment.
Injectors-ecu fried.
As well multitude of additional potential causes working individually or in conjuction with each other.
Need much more information.
regards
mech
98civHX (10-27-2015)
