Wow - what a PIA. Thanks for reminding me to be thankful for my sweltering heat rather than the mind-numbing cold!
Also - it does bring up a very good point. It's generally considered very bad practice to design something to work with only one part. I would like to know why the Tamura ones are limited to only -10C. The company does make sensors that can take the -40C to +85C range.
So, here are a few options - I haven't included the $200+ options.
1) LEM makes a similar part that could fit. It would require a pigtail wire, but could work with some slight design changes. Some cleverness would allow both the Tamura and LEM options.
http://www.lem.com/docs/products/hais_e_rev11.pdf
2) Design it for these little sensors:
http://www.allegromicro.com/~/media/...-Datasheet.pdf
The problem here is that they would need to be soldered to the busbars, they would be submerged in the coolant and the I/O wires/pins would have to be sealed. Or a different design would split the output pin. This would require some work to ensure the pin's strength.
3) Design it for these little sensors:
http://www.lem.com/docs/products/fhs%2040-p%20sp600.pdf
Paul already made a bunch of little circuit boards to take sensors like these. I suppose a little design tweaking and calibration would make this a good option. Also I don't know what the current limitation **really** is. It would be good to be able to handle 300A.
Frankly, I'd prefer the last option, if it can be accurate enough.
- E*clipse
