Old 10-28-2015, 01:19 PM   #19 (permalink)
98civHX
Originally Posted by Old Mechanic View Post
Most important at your mileage is to be absolutely certain the timing belt has been replaced. Documentation from the previous owner with a receipt from a reputable shop is your best insurance. A broken timing belt means bent valves and possibly much worse, up to needing a new engine.
regards
mech
Okay, thanks A LOT! I'll replace the thermostat with an OEM unit. My belts look great but one of them sounds loose. In the handbook it says that the drive/alternator belt has an automatic tensioner so would it be my power steering belt that is squeaking? Both belts look relatively new and have no signs of wear and tear.
