Old 10-29-2015, 07:35 AM   #2 (permalink)
MkVer
Tie Fighter 7 - '15 Chevy Volt
I'll let the veterans dive into answering your second question, but as for your first.
No damage. None. Zero. Your brakes are designed to be fail safe, yes some cars do have a pump to make braking a bit easier but you will still have full use of the brakes. Power steering will turn off but once you're moving you don't need it, the new fuel sippers coming off the line use an electric assist set up that completely turns off at highway speeds and again, it's a fail-safe system. Gearbox oil, if you're in Neutral your gearbox isn't turning, therefore no need for fluid to circulate.
The Following User Says Thank You to MkVer For This Useful Post:
Eddie25 (10-30-2015)
