On thing that really affects mpgs on Honda lean burn is EGR system condition. Are you getting any check engine lights? Make sure the check engine might comes on for a few seconds at start up to verify the bulb is functional. The main issue with the EGR system is clogged passages and sticky/faulty EGR valve.
