Old 10-31-2015, 12:43 PM   #362 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Originally Posted by BabyDiesel View Post
I have been spark knocking for quite some time. I have the knock sensor disconnected and 2 5.6K resistors on the IAT. While the knock sensor disconnect is Ford recommended, I feel the 2 resistors are tricking the PCM too much and causing part throttle knock.
The spark knock is not bad until my coolant temps cross 200* F. Above this, and I am spark knocking from 58%-75% load. It is a strange irony that above 200 degrees is where the ZX2 is its most efficient.
I don't remember the spark knock happening until I started ecomodding really hard. Advancing the timing, hot air, and a hot engine seem to be more than 93 octane can handle. FWIW, the car was nearly undrivable this summer on 87.
58% to 75% is a high enough load I would be very concern? Be careful.
Pressure Gradient Force
The Positive Side of the Number Line
The Following User Says Thank You to pgfpro For This Useful Post:
MobilOne (11-13-2015)
