Old 10-31-2015, 05:51 PM   #1 (permalink)
klroth025
Ecomodding Philanthropist
klroth025's Avatar
SOLD!!! 94 Civic VX for sale, 2nd owner, mechanically unmolested, $1500 obo
SOLD!!!
This is a running and driving Civic VX with 224k on the odometer, that I have owned for nearly 18 years, so I know everything about it. My best friend was the original purchaser. I needed a larger car (Accord), so sadly this has to go.
Aside from a drop in K&N air filter element, the drive train and suspension of this car are completely stock. The engine runs smoothly and the engine light is not on... no codes. Oil has been changed every 4k miles. Timing belt (water pump, seals, tensioner, etc) was changed at 91k, and again at 183k, along with complete fluid flush... all the things called for in honda "major service". Transmission bearing is a little noisy and the clutch will probably need replaced in the next 10k, but does not slip. Shifter bushing is wearing again, so it's not as precise as it should be. The car sat for a few months, so the brakes got some rust on them.
I had the rust around the rear wheel wells cut out and metal patched, a body kit added, and the entire car painted, all professionally in early 2004, but as we all know, rust never stays away. The body kit is very understated... I did not want to look like a ricer.
$1500 obo SOLD!
Thanks for looking,
Kevin
ID:	19001   Click image for larger version
ID:	19002   Click image for larger version
ID:	19003   Click image for larger version
ID:	19004   Click image for larger version
ID:	19006   Click image for larger version
ID:	19007   Click image for larger version
ID:	19008   Click image for larger version
ID:	19009   Click image for larger version
ID:	19011   Click image for larger version
ID:	19012   Click image for larger version
ID:	19013   Click image for larger version
ID:	19014   Click image for larger version
ID:	19016   Click image for larger version
ID:	19017   Click image for larger version
ID:	19018   Click image for larger version
ID:	19019   Click image for larger version
