Old 11-01-2015, 05:02 PM   #17 (permalink)
Isaac Zackary
Full sized hybrid.
Isaac Zackary's Avatar
Suzy - '13 Toyota Avalon Hybrid XLE
90 day: 37.18 mpg (US)
Mine also has the damper. I think it's call a dashpot. I have another one that doesn't work that I want to take apart and install a momentary micro switch to connect to the digital distributor as a way to signal idle timing. Maybe also hooked up to a set of relays in order to shut off the fuel shut off solenoid when engine braking.
