Old 11-02-2015, 03:12 PM   #52 (permalink)
320touring
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
I've been playing with the pump voltages on the map. The voltage controls the rate of fuel delivery - I.E. how close the pump gets to the theoretical 51mg of fuel max.
Apparently the highest you can set is 3.99v before you get into limp mode.
I built a version of the map with the pump voltages turned up, loaded it on and went for a run.
The onboard logging showed that it was delivering more fuel, more readily, and the car certainly seems more responsive.
I took it back off as the throttle response was bloody sharp, and would likely be a hindrance in day to day running.
Will keep it for the drag strip, as I think it may help
My Blog on cars- Fu'Gutty Cars
http://fuguttycars.wordpress.com/
US MPG for my Renault Clio 182
