Originally Posted by e*clipse
BTW, what is the logic for choosing the particular IC pins you used for this? There seems to be no particular order; the best I can guess is you wanted straightforward routing to the drivers. This seems like something that could be changed when routing the board. Is this correct?
- E*clipse
Do you mean the PWM1H, PWM1L, ..., etc? Or do you mean other pins? All the other pins were semi-random, and mechanically convenient for routing.
