Originally Posted by e*clipse
- How about pre-chilling a big aluminum chunk? Just stick it in the freezer for a while, then quick bolt it to a spreader plate for the test.
- I'm curious about this 'cause I want to try pre-cooling the battery pack. There's a HUGE mass/thermal mass in a battery pack.
- E*clipse
The biggest chunk of aluminum I have is the base of the Renault/Better Place pack .. but I don't think there is enough flat surface to mount to the controllers.
I'll see what I have kicking around. And if it fits in my freezer
If it's too big for the freezer, outside is 35 - 45F right now. That should be cold enough to pre-chill, depending on how big it is.
