BTW, you can shift the tranny with a bad TCM. Mine went out on mine. I replaced it for ~$20. I found a used one from my local Pull-A-Part.
Originally Posted by planejob
Ok, today I pulled the transmission so I can match the Kubota to the tranny.
I've got the engine plate coming this way (courtesy of eBay) and a plan to mate the two - thanks to some of the past posts from Kimer6.
From what I've read, when the auto tranny TCM fails you can still manually **** the tranny - folks, I'd love some input here. If I hook up the auto tranny with all of the mechanical connections (that's 2 total; the Gear shift and the kick down) will I be able to manually shift from first up to third - or- will it be a piece of junk that stays stuck in third? What's the failure mode of these slush boxes?
thanks in advance.
P.S. Aluminum has been ordered for the adapter plate. Woohoo. this is moving along nicely.
