Originally Posted by MPaulHolmes
Or you could do the testing with the base plate sitting in water. It could get to 100 degC, and then would definitely hold there, because it takes a ton of energy to evaporate water.
How well would the controller do in a pan of boiling water?
I could try a pan of oil .. but the cat would likely want to BATHE in it .. makes a mess ...
