Old 11-05-2015, 12:33 AM   #35 (permalink)
kimer6
Its a stock 6.5 with +1/3 turn on the juice screw. It has a 180 degree T-Stat, huge heat exchanger, 180 T stat oil cooler, power steering cooler, extra spring on the waste gate for 10psi. Mechanical injection pump, too. Dual mass flywheel. What do you want for a $400 engine off Craigslist... dang outdrive was $1600. I have a water intercooler but never hooked it up. Runs good as is. Top speed was 43mph on gps but the hull gets squirrely over 30. It originally had a 47hp Perkins inboard so it was never meant to go fast.
