Old 11-05-2015, 09:30 PM   #50 (permalink)
ctrlburn
White Jetta - '00 VW Jetta
Black Jetta - '15 VW Jetta TDI
Blue Golf - '14 VW Golf TDI
98 Jetta - '98 VW Jetta TDI
Zero - '13 Zero S
Originally Posted by spacemanspif View Post
An electric bike would be top priority but I'm not sure if the new job will have a place to charge it. I can't charge it in my apartment complex lot because of no outside receptacles; extension cord out the window is not an option as my apartment does not face the parking lot and is up on the second level.
The Zero FX has a removable battery. (actually it holds up to 2)
A couple Electric Mopeds I know of use removable batteries.
Most of the electric bicycles' batteries are removable.
So those would charge inside the apartment. Plus with the battery being nearly the most valuable part, you'll sleep easier.
Most won't need to charge at work - as can make the round trip. I "could" charge at work but my commute is only 50 miles round trip and my range is an easy 70-80. I got home today with 39% charge remaining without dipping into the charger at my parking lot.
