Old 11-06-2015, 02:33 PM   #34 (permalink)
Stacygifford
Eco Storm Chaser
Stacygifford's Avatar
Nemo - '87 Ford Mustang GT
90 day: 27.26 mpg (US)
K-sight - '02 Honda Insight
90 day: 39.24 mpg (US)
Originally Posted by Eddie25 View Post
. Can you tap into the PCV valve line? I have no other lines to easily tap in to..
Tapping into the PCV valve hose would not work very well. Generally speaking a vacuum metering instrument be it a vacuum gauge or MAP sensor ideally you would want its own port. If that is not possible You want it to be on a line that does not have any actual flow. A good source for this would be the fuel pressure regulator vacuum line (if on a fuel injected vehicle ) or the vacuum line leading to the solenoid for the EGR
Look at mediately behind the throttle body about you should see a couple vacuum lines regardless of vehicle manufacturer approximately a quarter of an inch in diameter
