Old 11-08-2015, 12:17 AM   #23 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
I've been messing with the Cougar controller today. I have an accurate resistance measurement tool - a Micro Ohmeter, or Ductor - and have checked the resistance of each leg of the MOSFETs to the B- busbar and to the M- busbar.
The results are confusing for me.
I had assumed that one leg of each MOSFET was connected to the M- and the other leg was connected to the B- copper bars. When M- is connected to B- through the MOSFETs, current flows from the battery pack + to B+ to Motor+, through the motor, to motor -, to M-, through the MOSFETs to B-, and on to the battery pack -
I have MOSFETs that during one set of measurements appear to have a poor connection to B-, but the same MOSFET has to good connetion to M-.
Table of measurements below. MOSFETs 1 and 3 have had their leads cut - scorch marks were a good hint that they had failed. But not just them!
Resistances are listed in milli-ohms
Code:
Measure resistance from B- to MOSFETs
MOSFET	Middle	Right
1		dead	dead
2		>200	14.7
3		dead	dead
4		3.9	10.1
5		8.4	0.7
6		3.8	2.6
7		3.7	9.6
8		3.7	22.7
9		2.8	1.7
10		3.8	16.4
Code:
Measure resistance from M- to MOSFETs
MOSFET	Middle	Right
1		dead	dead
2		>200	>200
3		dead	dead
4		2.4	9.3
5		7.0	4.6
6		0.6	50.0
7		0.5	6.4
8		0.5	19
9		0.5	1.7
10		0.5	13.0
I'm not sure what I was expecting. But whatever THAT was - THIS does not match it!
I took the Cougar out to my battery pack, put a resistor in series with it, then connected it first across 4V, then 8V, 12V, 16V and on up until I ran out of batteries. There was no current measured except for charging the caps. I was expecting current to flow somewhere. 12V was not connected to the Cougar at the time.
I disconnected the pack and just connected 12V to the controller. I checked for heat on each resistor. Nothing. I checked for voltage across the resistors that drive the MOSFETs. Nothing.
Paul - what am I doing wrong here?
