Old 11-10-2015, 12:16 AM   #2315 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Originally Posted by thingstodo View Post
I have no source code. I will power up the Cougar and see what it streams, then paste that into a message here. I am pretty confident that Adam's code will deal with the information in a different order .. maybe I should test that!
Sorry Paul. I powered up the Cougar, figured out (again) that I need a throttle connected to do much of anything, got a 36V pack connected, got the serial connected ... and it shows Cougar 1.11b just as it has many times, but the screen does not echo characters.
I tried rtd-period 1000 just in case - but no result.
I checked the serial cable .. it looked a bit rough so I made another one. Same result. I appear to have a part-time connection between the serial port and the processor that I need to track down.
I ran out of time tonight.
The Following User Says Thank You to thingstodo For This Useful Post:
MPaulHolmes (11-10-2015)
