Old 11-11-2015, 05:24 PM   #15 (permalink)
Frank Lee
Originally Posted by ksa8907 View Post
When i mentioned taking a theory to the limits. That is what is done with science to determine if the theory holds up at the extremes. This will tell you if your hypothesis is correct or if there are other factors.
Pressure obviously plays a role but it is not the primary concern. Maximizing the benefits of the exhaust pulses and the effect on scavenging are most important.
Right. We are talking about a system that operates at many frequencies and flow levels... not just one. It stands to reason that it will be difficult if not impossible to optimize a non-adjustable exhaust system for whole spectrum of operation. What we have now is just a rather crude compromise that delivers acceptable but not optimal results across the whole range.
