Old 11-12-2015, 06:36 PM   #3 (permalink)
S Keith
If you haven't had your 12V battery LOAD tested to confirm it is good, you need to do that too. Measuring its voltage is not sufficient. Most auto parts stores will test them for free.
Do the IMA, 12V and Check Engine lights (all three) come on when the ignition switch is turned to the ON position before starting?
