Old 11-13-2015, 01:05 PM   #6 (permalink)
rpearson
Honda - '03 Honda Civic Hybrid
Bucky - '05 Subaru Outback
the truck - '83 Toyota Pickup 4x4
Good advice, thanks. I'll head over to Autozone in a bit and find out. and check the lights.
Originally Posted by S Keith View Post
If you haven't had your 12V battery LOAD tested to confirm it is good, you need to do that too. Measuring its voltage is not sufficient. Most auto parts stores will test them for free.
Do the IMA, 12V and Check Engine lights (all three) come on when the ignition switch is turned to the ON position before starting?
