Old 11-13-2015, 02:33 PM   #14 (permalink)
Daox
Good point Joel. I'll look into that if I need to.
I got the pod redesigned a minute ago. I think this will work out a lot better.
I put a chamfer around the LED display hole. This makes it look a bit similar to the scangauge. Makes it a bit less bland too.
I may add something to the back side to hold the wires, but I'm not sure that'll even be an issue.
Here is kind of how it'll look. I didn't mention before, but the pod really doesn't block the view as much as the picture indicates. I can see the speedometer completely without any issues.
ID:	19084   Click image for larger version
ID:	19085   Click image for larger version
