Originally Posted by TimV
Ive got an (80)150amps alternator. So probably putting out 80 amps at idle.
I just dont have the ability to plug in with an extension cord.
So i aim forces to use this.
You can use a Diesel heater such as the one above, with a rated output power of 5KW. I had the glow plug setup on my older diesel and found it useless at other than killing engine torque at low revs. (It only heats up faster because of how much more fuel you have to burn given the engine inefficiency, which increases cold engine wear too) The car looked pretty stiff before the turbo kicked in because of the extra load.
