Originally Posted by Isaac Zackary
I wondered why you went from coolant heating to glow plugs. It would seem to me they should of thought of a better name. That's quite confusing.
As far as the intake grid heaters go, most new large international diesels have them. Freightliner too. Probably a few other large commercial vehicle diesel engines.
Always leaning
Haven't seen one in a while here!
The glow plug name is because someone had the idea to use the glow-plugs (same as used on the engine head) to heat up the coolant. More expensive models typically use a PTC element on the heater matrix, electrically operated, which helps to warm up the cabin while the coolant is cold:
Adaugare PTC (Auxiliary Heater) - VW Golf, Jetta, Caddy,Touran
And here is the glowplug version (check the first images)
ALH engine timing belt replacement VW Jetta TDI Golf Beetle 1998-2003: part 1/3 | VW TDI forum, Audi, Porsche, and Chevy Cruze diesel forum
These can be retrofitted into other vehicles or as a inline heater for the WVO folks.
basically it heats up the coolant (and creates additional engine load via the alternator) as it passes trough.
