Old 11-15-2015, 02:30 AM   #7 (permalink)
MobilOne
When you shift, try this: Push in the clutch pedal, then give the engine a little spurt of gas, just enough to rev the engine a little bit, then shift. This should help. Also, if you have a floor mat that is under the clutch pedal; try removing it.
