Old 11-15-2015, 08:21 AM   #9 (permalink)
ksa8907
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
Originally Posted by MobilOne View Post
When you shift, try this: Push in the clutch pedal, then give the engine a little spurt of gas, just enough to rev the engine a little bit, then shift. This should help. Also, if you have a floor mat that is under the clutch pedal; try removing it.
This. The idea is to rev match so you don't really need a synchro. When you clutch in, wait to put it in the next gear until the engine runs through the rpm range where that gear would be at the speed you are going. If done right it should be smooth as butter and no grinding.
The Following User Says Thank You to ksa8907 For This Useful Post:
MobilOne (11-17-2015)
