Gonna try 2 or 3 sheets of ¾" Foamular glued together with Liquid Nails LN-704 adhesive and sandwiched in between an upper layer and bottom layer of Coroplast fer the belly pan. It will be attached to two separate sections of ½" steel square tubing on top of the vertical supports via some Simpson A21 brackets and ¼" bolts. The belly pan will be attached to the bottom of the ½" steel square tubing with ¼" bolts and washers.
According to the application instructions...
Apply adhesive in temperature of 60°F or higher. Press material into place. Lift off for 2-4 minutes, then press back into place.
Recommended for interior installations and all common building materials, including:
• Paneling
• Corkboard
• Molding
• Foamback tub surrounds
• Drywall
• Furring strips
• Plywood/hardboard
• Masonry/concrete
• Foamboard
• Ceramic tile repairs
• Styrofoam® Brand Insulation
• Foamular® Rigid Foam Insulation
• InsulPink® Foam Insulation Board
• Medium density fiberboard
LN-704
TECHNICAL INFORMATION
Base: Latex emulsion
Color: Off-white
Appearance: Smooth gunnable paste
Application Temperature: 40° to 100° F (5° to 38° C)
Service Temperature: up to 120° F (49° C)
Adhesion: Excellent to most common building materials
Bridging Ability: Good; bridges gaps to 1/4" (.64cm)
Shear Strength:
24 hours – 300 psi
48 hours – 350 psi
28 days – 400 psi
R.T. Static Load in Shear: 10 lbs. No failure in 72 hours.
Tensile Strength:
24 hours – 60 psi avg.
7 days – 75 psi avg.
Durability: Resistant to oxidation, 20 year life
Flexibility: Good
Water Resistance: Good
Aging: Good
Freeze-Thaw Stable: Passes 5 cycles
Bleed: None
Staining: None
Odor: Mild Acrylic
Working Time: 30 minutes
Weight Per Gallon: 12.18 pounds (5.8 kg)
Viscosity: 400,000 CPS
Volatiles: 38%
Solids: 62%
Flammability: Nonflammable
Flash Point: Exceeds 200°F (93°C)
Coverage: Using full round 1/4" (.64 cm) bead:
10.5 oz. (310 ml) - 32 lineal feet (10 lineal meters)
Shelf Life: 12 months from date of purchase
MAX VOC: 14 g/L
