View of the updated belly pan support system. Pulled the zip ties off and installed a 1"x2" section of wood to fill the space between the tubing and the belly pan. The wood section will also allow fer me to insert a gap spacer between the front tubing and the belly pan. I will have to work on that spacer in the morning. The skeeters were homing in on me!
Front view...
Front side view...
Rear view...
