Thread: Low cost BMS
Old 11-19-2015, 09:24 AM   #120 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Originally Posted by arber333 View Post
Oh, you have a special driver board? And the way you say it, driver chip is glued in some resin? Can you send a photo of the driver board? The one that is connected to IGBT.
The DC controller is a commercial Product - Netgain Industrial Controller NetGain WarP-Drive Classic Controller - there is potting compound on some of the circuit, or parts of the circuit.
I have no schematics. I'll get the pictures posted tonight.
Yes when i heard bang i knew one of the motor winding coils backfired and IGBT got it all. Poor thing exploaded. Even the top blew off. Yes scorch marks were visible, but i took all 3 IGBTs off and measured them just in case.
I had a big bang as well. No scorch marks visible. It may be possible that the BANG was the fuse element blowing apart? I expected there to be scorch marks, shrapnel, etc but the inside of the controller is quite clean?
Usually only the top transistor in IGBT is toast.
Drivers i tried with my PSU and if the chips draw more than couple mA something was wrong. With the chips i use sometimes even the DCDC converter is toast, but not allways. So whatever you find you check the pricing and decide.
I need to make an extension cable so that the controller is connected to external signals - contactor outputs, throttle signals, precharge voltage, etc - while the controller is in pieces. That way I can see how far the signal makes it before it stops - transistor, optocoupler, or blob.
