Old 11-19-2015, 08:52 PM   #132 (permalink)
Vman455
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Originally Posted by Old Tele man View Post
Weight is down roughly 200 lbs -- 3075 lbs vs. 3275 lbs -- due mostly to lighter Li-Ion battery. As yet, no actual ET times.
We ARE talking the ECO model?!?
Weight is up, actually, unless you get the Two Eco. 2015 weighs 3,042 lbs (across all trim levels, according to Toyota, except PiP); 2016 Two weighs 3075 lbs; Three and Four weigh 3050; Three and Four Touring weigh 3080. The only trim that got lighter is the Eco, at 3010 lbs, and it loses the spare tire that comes with all 2015 trims.
Edit: Whoops--I misspoke. Toyota quotes the 2015 at 3072 lbs on their website; earlier years were 3042 lbs (they added some material in 2014 to improve offset crash test ratings, which probably accounts for part of that gain).
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following User Says Thank You to Vman455 For This Useful Post:
redpoint5 (11-21-2015)
