Old 11-19-2015, 10:50 PM   #1265 (permalink)
NeilBlanchard
Okay, the nose is longer with a more graceful angle. The exhaust is shrouded along the right side rocker panel. The rear hatch is slightly different profile. The front wheel fairings are cleaner. The side mirrors are much better. They are showing it with the manual shift, which is the base model. It has got some sort of a tablet shown on the right side. The door handle looks clean.
It looks like it has more ground clearance - maybe it has the 15" wheels they mentioned? They look taller and narrower:
Engine: 3 cylinder 900cc 60HP 55ft/lbs
