Old 11-20-2015, 12:30 AM   #11 (permalink)
oil pan 4
My mechanical engineer friend had a cracked exhaust manifold on his 4-cyl 2.7L taco, which in Virginia means you to fail inspection.
He has fuel economy logs going back to 2005 for this truck.
New dealer part was something like $800, a used one off the internet was $500. A pacesetter 4 into 1 header was $400.
He put the pacesetter header on in 2010 and it is still going good.
He says the header appears to have not hurt fuel economy at all, but is half the weight of the cast iron manifold and has increased low end torque and high end get up all around.
For the metro header, if were going to build one I would use 1'' diameter 0.62'' wall 304 stainless. Not sure how long the tubes would be.
