Old 11-21-2015, 04:15 AM   #2336 (permalink)
P-hack
P-hack's Avatar
awesomer - '04 Toyota prius
Originally Posted by e*clipse View Post
Those boost switches would probably need to carry more current than a phase leg.
That is what I was thinking when I saw 4 power sections
the chunky prius booster switch has to carry the conversion current for all three phases, i.e. if the converter output is 150a @600v, and the input is 300a @ 300vish, the inductor sees 300a, the top diode sees 150a semi constant (depending on converter design) and the bottom switch swings/chops between 300ish and zero. Meanwhile the inverter switches only have an average of 50a each to deal with.
