Old 08-01-2008, 04:59 PM   #33 (permalink)
Noel
If you use a normally open relay for the starting battery, this means that if the relay fails, it's normal working is a connected battery to your car. A manual bypass switch wouldn't be a bad idea either.
I can get by without a starter, I can't get by without a fuel pump.
Another option is an actually switch inside the car, but that's a lot of heavy wire to run.
