Old 08-01-2008, 05:32 PM   #10 (permalink)
homeworkhome53
homeworkhome53's Avatar
Workride - '07 Chevrolet Aveo5 SVE
90 day: 51.74 mpg (US)
P&G throws the scangauge off. The scangauge is usually within .1 gallons at fill up. It was .5 gallons low this time 4.4 scangauge 4.911 actual). The mpg did improve, but not as damatcially as the daily number based on the scangauge would indicate. This was about 45% p&g. From the numbers I was getting I thought 56-57 over all. It was 53.75, Bought a kill switch and will wire it into the fuse block so that only the fuel pump is effected. Then see what happens.
hoimeworkhome53
