Old 11-23-2015, 01:47 PM   #1 (permalink)
Daox
Toyota SF-R - a Miata fighter concept
Looks like an interesting and fun car. Probably not super aero, but also not a horrible base for modification either.
Leaked Specs: Toyota SF-R Has 130 HP And Weighs 2160 Lbs - Art of Gears
2NR-FKE engine (tuned version of the one used in Japan’s Corolla, now with direct injection and revised ports)
1.5L inline 4 cylinder dual-overhead-cam (DOHC)
130 PS / 15.1kgf.m (109.2 lb-ft torque)
Aisin 6 Speed Transmission only (no automatic)
Fuel consumption: 20.0km/l (47 mpg) (Japanese test cycle)
Regular gasoline (no premium needed)
Weight: 980kg (2160 lbs)
Suspension: Front struts / double wishbone rear
3990 mm length, 1695 mm width, 1320 mm height, 2480 mm wheelbase
Estimated price (Japan) is $10k (USD equivalent) less than the current Miata
Note: 1.5L Miata is $20.8k including tax in Japan, S-FR is estimated to be $12.5k including tax
