Cracked exhaust manifold on 98 hx
I have read that the D series (96-00) have issues with the exhaust manifold cracking. I think mine just did as well but haven't had the time to check it yet. My ultragauge is also telling me that I have a p1164 code (o2 sensor). I did some researching and read on a different forum that 98hx's have a glitch in the ECU that may cause o2 sensor to go bad soon again. So, I have a few questions you guys might be able answer.
#1 what is a good aftermarket exhaust manifold brand I can buy for my car that will be similar to my OEM manifold?
#2 does anyone else know about the bad ecu that needs to be replaced from the A-32 to the A-33 ecu?
