Old 11-23-2015, 10:35 PM   #2363 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Update for Nov 23
I bought a multi-turn pot for accurate throttle on the AC controller - so the throttle should work for the next test - likely Wednesday or Friday - just a small bit of soldering required.
Lighting for the meters: they are hard to read. Some lighting is required, and I'm going to try moving them to where they don't vibrate (not on the motor base).
A quick test with a couple of LED flashlights seemed to work OK. The angle is important so the camera can read the numbers. Maybe a cardboard stand to hold things in place so the phone and lighting stay where they need to be?
There WILL BE DUCT TAPE!
The Following User Says Thank You to thingstodo For This Useful Post:
MPaulHolmes (11-23-2015)
