Thread: Quick question
Old 11-25-2015, 03:08 AM   #4 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Putting a grill block behind the grill is a lot more work. Not only do you have to get behind the grill, but it's usually not a flat surface that's easy to cover either. And air pressure on a grill block behind a grill will try to push the block away from the grill and let air in. When mounted in front, the air pressure pushes the block tighter to the grill. I wouldn't expect an aerodynamic difference between the two methods if it's well done.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
carolina guy (11-25-2015)
