Old 11-25-2015, 07:30 PM   #5 (permalink)
oil pan 4
I will try the a PWM controller.
I liked the resistors because they could stay under the hood.
The PWM controller might not care for the heat.
I ordered a 4 pack incase I fry some.
Also picked up some 0 to 60 second time delay relays. That way the engine is not cranking while the pump is trying to run, PWM controllers may not like that.
Only problem I see is these pwm controllers need 12v, with an alt delete system volts may drop below 12 volts some times.
