Old 11-26-2015, 04:38 AM   #14 (permalink)
gumby79
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
My 91 dodge d250 diesel worms faster with the defroster on. Noticeably faster ..
1 small load is not sufficient to add fuel at idle slows thw motor insted
2 heat from the condenser helps to worm the coolent in the radator
3 the added heat helps the thermal fans viscous fluid to sleng out and disengage (slow almost stops drawing in freezing air through the coolant)
4 ac condenser coil is in front of my intercooler. Heat is transferred to my intake air charge via the intercooler
The important things to remember
1turn fan speed down to 1 / low till wormed up
2 turn to plain heat to disengage the compressor
As for transmission heating dodge released a tsb saying not ro use overdrive@ temps below 5°f because the atf will freeze in the air to liquid transmission cooler and burn up the transmission. So a 12 volt heater would se good in my application. It would alow me to run overdrive(higher gear trumps additional altanator1load )
Add thermal isolator tape , sleeve, split loom, on all coolent hoses to reduce heat loss (ever try to hold on to a heater hose @ operating temperature? Wellits operating temperature!! ) my 2cents well spent
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
