Old 11-27-2015, 06:19 PM   #93 (permalink)
aardvarcus
aardvarcus's Avatar
Deep Blue - '94 GMC Suburban K2500 SLE
90 day: 23.75 mpg (US)
Griffin (T4R) - '99 Toyota 4Runner SR5
90 day: 25.43 mpg (US)
So I got the step/slider/bellypan all mounted up. Started by drilling out the aluminum, then transferred the marks onto the slider frame. It was hard drilling all those large holes up into the steel slider frame, but I managed. Popped in all the Rivnuts, and then drilled out tapered holes in the aluminum, so the V headed bolts would sink up flush. I need to get two longer V bolts, since the end pieces are a little too thick, so temporarily I have some normal M8 bolts holding them in.
ID:	19174   Click image for larger version
ID:	19175   Click image for larger version
ID:	19176   Click image for larger version
ID:	19177   Click image for larger version
ID:	19179   Click image for larger version
ID:	19180   Click image for larger version
ID:	19181   Click image for larger version
The Following 2 Users Say Thank You to aardvarcus For This Useful Post:
aerohead (11-28-2015), BamZipPow (11-30-2015)
