Old 11-27-2015, 07:58 PM   #13 (permalink)
mort
EcoModding Lurcher
mort's Avatar
Originally Posted by cyclopathic View Post
Car: Prius C.
was traveling last weekend. After stopping for gas and pulling back to interstate, "from the start" MPG was holding on at steady 38-39MPG. This is on flat surface with cruise set at 73mph,
It normally gets 58-60MPG in commute.
According to calculator above the load should have gone up by 25%, and if you consider torque to be constant RPM (load) had gone up by ~50%.
Hi cyclopathic,
What's the problem? If you take a load (power) increase of 25% and a speed increase of about 20% You get a work increase of 50% which should be the same as the rate of increase of fuel consumption, if the engine efficiency is unchanged.
-mort
