Old 11-29-2015, 04:46 PM   #28 (permalink)
pete c
Seems to me that the only was an alternator with a substantially higher weight makes any sense is if you have...
a. increased battery capacity with the ability to charge at a very high rate
and...
b. a smart charging controller which would allow you to go to a high charge rate when you wanted to slow. MAybe even have the ability to go to a low level of power output when acceleration was needed for short periods
