Old 11-29-2015, 11:40 PM   #33 (permalink)
dremd
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
Yeah, I totally doubled my real world MPG going from 1.8T auto to current setup.
Worst tank(s) to date with current setup was towing a large enclosed trailer empty at 29.9 MPG and back loaded with about 3000 lbs of workshop + a 1200 lb trailer at 29.4 MPG.
I regularly get 47-49 MPG unloaded and the 1.8T was a struggle to hit 25 MPG.
I ditched the higher temperature Stant thermostat when I blew my head gasket right at a year ago now. I never lost coolant (level) BUT I had 2% anti freeze in my oil (thank you Blackstone labs!) and there was quite a bit of oil in my coolant that wasn't super evident until I flushed it while changing head gasket. I DONT NECESSARILY blame the BHG on the huger temp thermostat, but the way that I use the car it is probably much better to have some extra safety margin. I'm sending off my first oil sample since the BHG (20,000 mile oil change interval) tomorrow wish me luck.
The car has turned more in to a truck than an eco modded car, I'm running a VNT 17 turbo (keeps exhaust temps down while towing stuff heavier than the car), the stickiest LRR tires I could find, much bigger brakes up front and stock TDI front brakes in the back in attempt to keep every thing in check.
I'm really interested in Halfing my transportation carbon foot print again by picking up a used LEAF for what I call my Prius duties that accounts for about 75% of the miles that I cover in the TDI.
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
The Following User Says Thank You to dremd For This Useful Post:
COcyclist (11-30-2015)
