fuse, power to the pump (read at the pump itself), relay energization circuit (need a wiring diagram).
bad relay
bad pump
bad ignition switch
bad ground
wiring defect in the circuit
no gas
fuel tank pickup damaged or bent where it will not pick up fuel
regards
mech
